Setup Questions from a newbie
toyjoha
This must just be like livin' in Paradise...
I am lost on what to do and I am requesting some help. All of the components that I have, I took off my boat. I did not install them on the boat. I have tested all of them with a multimeter. I looked up the specs on all of them.
Here is what I am working with:
Front Speakers: 5.25 4-Way
RMS: 75w
Peak: 150w
Impedance: 4 ohms
Freq Resp: 85 Hz - 20 kHz
Sensitivity: 93dB
Middle Speakers: 6.5 2-Way
RMS: 75w
Peak: 150w
Impedance: 4 ohms
Freq Resp: 100Hz – 18KHz
Sensitivity: 90 dB @ 1 W/1 m
Back Speakers: 6.5
RMS: 20w
Peak: 100w
Impedance: 4 ohms
Freq Resp: 45Hz-12kHz
Subwoofer: Massive Audio GTX104
10 inch
DVC
RMS: 700w
Peak: 1400w
Impedance: 4 ohms
Freq Resp:? kHz
Sensitivity: 87.5 dB
Amplifier: Rockville RMX-S6
6 Channel
Dual 2 Ohm, 2.5 Inch Voice Coil
RMS: 700 Watt RMS,
Peak: 1400w
Here is what I am thinking:
Channel 1 Left front speaker 70w@4 Ohm
Channel 2 Right front speaker 70w@4 Ohm
Channel 3 Left Middle and Back speakers 70w@4 Ohm
Channel 4 Right Middle and Back speakers 70w@4 Ohm
Channel 5
JUMPED to Sub in series
Channel 6
Thanks in Advance,
Rev. Jimmy
Are your rear and middle speakers 8 ohms? If they are 4 ohm speakers you would have 2 ohms once you wire them together. If your amp can do 2 ohm, it would work fine, otherwise those speakers need to be 8 ohm speakers.
They are all 4 Ohms. I did not think that I could push them to 2 ohms. Plus wouldn't that increase the watts to higher than the rear speakers can handle?
Just curious what 5-¼" 4 way speaker you are using up front? Why not run the 6-½'s up front?
Won't fit. I even had to get adapters for the 5.25 to fit. Factory was 4x6. I know you might be thinking they are the doors, but it's a jeep and we have not had the doors on since we bought it 7 years ago.
RMS: 75w
Peak: 150w
Impedance: 4 ohms
Sensitivity: 93dB
RMS: 75w
Peak: 150w
Impedance: 4 ohms
Back Speakers: 6.5
RMS: 20w
Peak: 100w
Impedance: 4 ohms
10 inch
DVC
RMS: 700w
Peak: 1400w
Impedance: 4 ohms
Freq Resp:? kHz
6 Channel
RMS: 700 Watt RMS,
Peak: 1400w
Channel 5
Channel 6
Thanks in Advance,
Rev. Jimmy
You figure it out yet? Amps not nearly powerful enough. Sub is 700 watts RMS. Amp is 700 watts RMS at 4 ohm.
That's all you should be powering with that amp.
And thats a perfect match btw.
Now add up the # of speakers and multiply by 70. Its 8 speakers? Find an amp that runs 600 RMS at 4 ohm and youre good.
Sure we need to grow up, ok. I gave you the exact answer then you blew up on me saying I was wrong. Time for self reflection bud. Cant take...
20
Subwoofers have a certain range in box size they want to be in. Measured in cubic feet (usually). Look up the specs on your Kenwood sub and see...
767
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
toyjoha
toyjoha
Key West, FL
Bellmeister
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
