help with fuse size in holder near battery and distribution block
  • 3
mr roo
CarAudio.com Recruit
All, I am helping my son with an install. We will use several pieces of equipment that are in my left over from things I previously ran.
For amps, he will run two Polk Audio PA D2000.02. Each amp is rated for 125 x 2 at 4ohm and 400 x1 4 ohm bridged. Each amp has dual 25 amps internal fuses. I will run 1/0 from the battery to a Streetwires CBR 44a agu combo fuse and ground block. Each amp will receive 4 AWG from the fuse blocks. All wire is OFC. I know the wire is possibly overkill, but we already had it on hand to use.
My question is what fuse would I run at the fuse holder near the battery and then which fuses would I run in the distribution block for both amps? I was told that 250 in the fuse holder at batter and 50 in distribution block for each amp would cover, just want to make sure if that is true?
250 at the battery might be overkill. Itll work but 125 would be less smoke if something does short out.
50s at the dis block sounds good 🤷‍♂️
Yeah, 125 - 150a would be plenty at the battery. I would use a circuit breaker at the battery instead. It allows you to cut power to the whole system to work on it or whatever.
Like this:
Question about the ground I have a small xs power battery. I know to run the 0 gauge to it then off that to the block. Do I have one spot for the...
16
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
417
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
522
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
538
mr roo
mr roo
Richmond Va
ThxOne
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
