Installing second underseat sub
  • 3
martinv_357
CarAudio.com Newbie
nz
Hi guys,
I have a Cerwin Vega VPAS10 installed using a high-level input from my speakers. I would like to install a second VPAS10 and was hoping someone could tell me whether I'm able to tap into the power, remote and speaker wires that are currently in the first sub, or whether I need to repeat the process again?
Thanks in advance.
Hi guys,
Thanks in advance.
Uhhh. Yes.
As long as your power and ground are 8 gauge or larger. Rem and speaker inputs should be fine.
Good luck trying to get the gains set the same as each other 😬 shouldn't affect it too much at 200 watts a piece though.
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
393
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
martinv_357
CarAudio.com Newbie
martinv_357
nz
Kickstand
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
