WTB Amp Install Kit 4 gauge
You dont really wanna cheap out on wire. If you need inexpensive (not the same as cheap), get an 8ga spool and do multiple runs. Three runs of 8ga equal 3 ga and a 100' spool costs about the same as 25ft of 4ga, but leaves you more than enough to also use that a ground, assuming youll label it as such. You will need one fuse for each run though, but they can be smaller glass fuses then. Make sure you get OFC, not CCA.
https://www.wirebarn.com/Combined-Wire-Gauge-Calculator_ep_42.html
Yea figured someone had a set they wasnt using.  Guess going to get off 4ga kit for 69$
My dad has oneand we are sending it off to have the internals switched with modern equivalents as well as cosmetically refurbished. I want to...
  • Locked
I got a Gladen RC-90C2 thats pretty small 90x2 @ 4 ohms i'll be removing from my rig in a few days if interested.
  • Locked
I have one if you are still looking
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
574
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
Ripkon
CarAudio.com Regular
Ripkon
Virginia
Ripkon
Brendon Jenness
    May 8, 2024
    May 8, 2024
