upward firing sub box help
  • Thread starter Starkillers2019
  • Start date
  • Replies 13
  • Views 1K
S
Starkillers2019
Guest
should i face the ports     forward    or to the trunk        subs are both facing up      also 3  ports on one  side  with plexiglass windows.    otherside  is completely  bare carpet.       i  could also go  subs forward or back    plexi and ports up. looks kinda crappy this way though..        box is a real tight fit side to side.    and moving it just *****  lmao
Wow... sounds like you went ported.
Something like this maybe?
Glad you decided to listen somewhat, what vehicle do you have it in?
Yeah that other one lol. I remember sealed arguments something about batteries etc. Had questions but seemed to already know The answers if I remember right.
Gonna try to power them decent iirc.
If he has 3 4" ports on that thing... idk.
With any real power applied that enclosure is going to limit output I'd think, but what do I know? Maybe Op shoulda asked for specifics?.. oh thats right I think he got a few pointers about area iirc.
Probably be another thread soon asking why the thing either dont dig or put-out as well as expected.
install complete.  well nothings 100% mounted  just loose  laying around still....not sure if ports should face foward or back yet.   not to bad   thanks for the no help at all.   for u 🖕🏻   thank you emoji
brooo you shoulda went sealed. the manufacturer said you can use them in sealed ROFLMAO
i can always plug the ports up if needed.     ( ROFFYWorG)     try to figure this one out   it isnt to nice  but  just for you..    it does involve ROF  though
When I see a box like that, I always wonder what the tuning frequency is.... :fro:
As long as you are happy with its performance is all that matters I say!...winning!!!!
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
489
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
346
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
490
Guest
DRBOOM
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
