JVC Head unit flashes with the music
Stumann666
I just bought a new head unit, a JVD KD-T700BT.  The display flashes with the music and I can't figure out how to stop it.   I even downloaded the more complete manual for JVC, but I can't find the info I'm looking for.  I want it to be a steady light.   What am I missing?
I figured it out. Press the menu button repeatedly during playback (short presses, we don't want to go into the menu) this will cycle through all the display modes, showing title/ artist/time remaining/ etc.. Once you get through all the options it will enable/disable the pulse and cycle through the same options again. Just pick your favorite. Done.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Ok thanks I removed the wires from the back of the unit
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Stumann666
Stumann666
Tailoreddj
    May 22, 2024
    May 22, 2024
