2014 silverado subwoofer
  • 2
Tactical enigma
Hey guys I wrecked my 2003 Silverado and have recently gotten a 2014 silverado. Wow things seem like they have become a lot more complicated in the stereo world with these new factory setups. I was running 2 JLW0 v3-4 on an alpine 500 watt. I was very happy with the setup as you guys reccomend it.
My question is, I want to run dual downfiring 10" subs and I have no preouts and no idea what I am doing and where to start to get preouts. I want to retain the factory head unit but I want it to sound good.
As a side note I have weathertech mats in the truck and am not sure if they will have any effect on subwoofer clearance. Any input would be appreciated.
Thank you all for your help and knowledge
Justin
What Alpine amp? If it has speaker level inputs then use them and tap into the speaker wire for a signal. IF not then you will need a LOC. Use the LOC to tap into the speakers and then it will have RCA out.
If the factory radio has any bass roll off at higher volumes the LOC should have some correction for it like the Audio Control LC2I.
The amplifier that I have is the alpine mrv m-500
What way would sound better? It appears that this one does have a speaker level input. Last time I had it connected via rca
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
965
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
661
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
984
Tactical enigma
Tactical enigma
ckeeler11
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
