Remote Wire Problems
  • 1
CruzeLow85
First off, hello all!
I have an older install that is driving me crazy and need some help.
2 10" soundstream 300rms @ 4ohm each
1 soundstream 175w per channel 2 channel amp
4ga B+
4ga Ground
I recently bought a Rockford fostgate R500X1D amp to add to power as the amp I had was underpowering the current subs. The current amp powers and plays fine running each sub at 4ohms. The problem is when I pull the old amp. When I wire up the new amp  @ 2 ohms will not power on. I thought it was DOA so got another one (same kind). The new one won't power on also. I spent all of last night checking all connections to no avail. B+ gets 12v, Remote gets 12v and ground is good. Swap back out to the old soundstream and it powers up fine.
Update:
I messed with it this morning and noticed that if I put power from the B+ to the remote the amp comes on. The remote wire will still turn on the old amp no problem.
Should I just run a new wire from a fuse instead of from the remote lead on the HU?
Has anyone seen this happen previously?
yeah, it'll be hot but off. Just like your tv when it's plugged in.
Remote turn on. Going to check it later this week. Almost 100% certain it's something with the amp. I am assuming that a resistor inside went bad...
With the amplifier fused it will be fine for testing an amplifier to see if there is an issue with the remote wiring coming from the HU, or great...
As stated..A jumper wire from remote to Power on amplifier will be a nice little test to see if the amplifier is working. If it does, I would...
CruzeLow85
CruzeLow85
CruzeLow85
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
