Kicker Display
  • 1
373
902
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Kennyp
Kennyp
Kennyp
    Apr 26, 2024
    Apr 26, 2024
