Kenwood DDX795 question
  • 3
Polar
Question about a Kenwood Excelon DDX795. What would cause zero increase in volume from say, 25 on the dial and upwards( maybe I am finally going deaf?) No noticeable volume increase and it seems to " roll off" the bass. In the eq it has a few setting, many which I dont understand. For instance, bass extension and drive eq. I have an email into them and the manual does not explain very well. Thanks!
turn off all eq enhancement settings. it sounds like you have a loudness setting turned on. What is the max volume number just to put the 25 number in relation to something
Polar said:
40 is the max, there is like zero volume increase from 27 all the way to 40
I had a similar issue with my eXcelon. My EQ is a 13 band, each band is -9 to +9db. All of my bands were ABOVE 0db. Set your EQ bands BELOW and only UP TO 0db. See if this helps... it helped me.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
321
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
801
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
619
Polar
Polar
WPB, Florida
ThxOne
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
