2 Skar 15" Isobaric 8th Order Bandpass HELP!!
  • 2
Elyjah
I recently bought 2 600watt RMS Skar 15" subwoofers. I have to pair with them a dual channel 1500 watt RMS Skar amp. I'm relatively new to fabricating boxes but I've done plenty of research and know about 95% of the process. I am putting this system into a 2013 Chevy Malibu which has a 16.3 cubic foot trunk. I did some very rough measurments and I need to know if this rig would even be possible to fit inside of a 36x38x19 in box. I want the tunning to be at 30hz, 50hz, and 70hz. What I'm really wanting to know is if this is even possible with the space I have to work with and what the measurments would roughly be for everything.
Thanks for reading, any feedback would be great!
399
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
922
840
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
Elyjah
Elyjah
THATpurpleKUSH
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
