Best budget 2nd battery?
We did the preorder sale on the Wolfram 2400.1. Used the GEM code from bigblanks video and got it super cheap! We've been running the 1600w amp we have now on stock electrical in our 2008 Yukon Denali XL. I'll be adding the big 3, a second battery and a volt meter. What would be my best choice from Sam's Club? Any other place I should be looking? Thanks.
I used 2 Deka marines, I prefer the 4 posts. 1 under the hood, other in the trunk. Not sure on if I want a battery isolator, but keep your batteries about the same. These were about $90 each. Find a dealer close to you.
Sent from my SM-G955U using Tapatalk
I like my 80ah limitless
But seriously...if you have a Battery Outfitters or similar in your area check with them. Before moving to lithium I had 3 refurbished Odyssey 2150s that worked great. They were around $70 each.
thats quite a deal on a battery that is around 330 to 350 new!!
592
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
955
841
Interpreting your question as "what's the cheapest SQ head unit" the answer is: Pioneer DEH 80 PRS. That's sort of the most famous "entry level SQ...
Muffdogg
Muffdogg
Muncie, Indiana
osl
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
