brutal sounds bs2.1 dyno WTF over 90% efficient???????????????
Brutal doesnt care much about profit margin.
When their 5k came out, they were selling it so cheap that Zenon emailed them that other customers of that board were complaining about Brutal undercutting their prices. (B2 and AL both have a 5k with that board)
but how they make it so efficient? every company should charge $50 more and use whatever part does that lol.. if u could run a 1500rms amp on stock electrical with no problems it'd be worth the $50.. i also don't think i've seen a amp do double rated before and diff not at 4ohm
Something was wrong with the clamp.
Stop butthurting the fanboys!
Ratings don't mean anything. The manufacturer knows what it puts out and underrates it for a wow factor.
Send it to us, we'll test it here and get you true efficiency readings along with graphing, etc..
IVe never seen nor would accept an amp would increase efficiency with lower resistance.
I'd be interested in debunking the results.
I'd be willing to bet it has to do with the power supply caps. They should be drained by the end of one of the certified/uncertified tests but it's hard to say.
A real answer would be taking total power used (as in area under the curve) of the input and output and calculating based on that
Clamps just fine, it's really a matter of resolution in time and the tool not being "right" for the job, although it is a great ballpark. If you had hundredth of a second resolution and data logs it would give you a much better idea of actual efficiency
It really doesn't...... All it explains is that you want the certified number and not the uncertified number or dynamic. Adjusting the gain upwards could only change the certified number if you end with a higher voltage (quicker build is easier on the power supply / batteries), but it won't change the end result if the ending voltage is the same... Same with the uncertified number.... sometimes the uncertified test can end before the clip point... you can adjust upwards to reach the clip point faster... but when you clip.. you clip and the test stops.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
543
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
The formula is Square Root of your target Wattage Multiplied by Ohms. 50Wx4Ohms=200. Square root of 200 is 14.14. So 15v AC is your target.
BOOMINGRANDPA
WOLFRAM FTW
BOOMINGRANDPA
NC
bigblank69
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
