Alpine Type R or S, or something else???
  • 5
Symon_say
You can't get me
Hi
I have new vehicle and that means new system, i want a SQ system, I'm planning on installing a 15" in a 2.0-2.5 cu.ft sealed box and i have a JBL ms-5001 that have 500W (sonix electronic say it produce 692W@2ohm), maybe i can upgrade the amp later, but that is not priority specially if i like how everything goes.
I think Type S fits the bill nicely, but Type R is in budget reach, i don't want to spend more than $200 on this.
Front stage will be JBL MS-62C hooked to JBL-MS1004, I'll probably run then active.
With $200 budget, 500W and 2.0 cu.ft sealed box, Should i go with Alpine S or R, or should i get something else??
Thanks, I was reading about Dayton UM, but they only have 2dvc and from what I have read the need a bigger box.
About the Dayton HO I used to have one of this and is a really nice sub, but it's only 12".
I have been inveatigating and it seen like I can fit a sundown e15 v3, will it be more musical than type s?
get the sundown E and amp like mine ppi p1000 it does 930rms @ 2 ohm (sonic tested it does 1162 @1ohm) set gain low be loud and u have amp tht'll allow u to add 2nd sub or get bigger sub later.. get sundown bstock at car audio bargain $128 or so and amp on amazon $153 sound really good for that $.. except for 2.5cf box u could get the 12 for $95 and get ported box..
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
298
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
I would just go with a ported box tuned from 32 hz. - 35 hz.
Symon_say
You can't get me
Symon_say
Dominican Republic
Symon_say
Brendon Jenness
    May 8, 2024
    May 8, 2024
