USB Audio problem
  • 3
xhuffs
I have a Kenwood DPX502BT headunit, and when i use USB, it almost sounds like my speakers are blown, but only on some songs and not all the time, the speakers are brand new ALPINE SPE-6000 6.5in coaxial two-ways. The USB cable is torn pretty badly, but not through the signal cables, so it works fine. however, when i use AUX the speakers sound perfectly fine with no issues, is it possible that because the USB cable is torn around the outside and through the metal coating, which i assume is the ground, that it has affected the sound quality? I am using an iPhone 6 with the original iphone cable. I have not tested the headunit with a different cable. any ideas?
Almost Everytime I switch it or someone i see switch from aux to usb this happens. I've chalked it up to the usb being better quality, thus u don't have to crank on the volume near as much
if the shielding on the usb is damaged, youre likely going to have a problem, byt one would think that it would just not work at att, not introduce such noise as the music isnt music until after the DACs
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
e heard decent things, I've not used it, but for noobs, good place to start with that new DSP setup...
For anyone that has an Alpine ilx-w650, do you have a crappy shuffle feature when using a USB or is it just me? A little background, I have...
Good luck. Front facing USB it's rare and it's not hard to reroute a USB from the rear. 300 isn't enough for any quality touch screen with 3 sets...
10
974
xhuffs
xhuffs
Orlando, FL
youdoofus
Mr FaceCaser
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
