Skar Sk85.4
  • 2
Fireitup
Alabama
1. Product:
Title^^
2. Specs:
Class AB Multichannel Amplifier
Compact & Versatile Design - Highly Efficient
RMS Power @ 2 Ohm : 125 Watts x 4 Channel (14.4v)
RMS Power @ 4 Ohms : 85 Watts x 4 Channel (14.4v)
RMS Power @ 4 Ohms Mono : 250 Watts x 2 Channel (14.4v)
Frequency Response : 20Hz~30,000Hz
Input Sensitivity : 6V~0.2V
Line Output : Yes
Low Pass Filter @ 12dB Slope : 50Hz~5kHz
High Pass Filter @ 12dB Slope : 50Hz~5kHz
Damping Factor : 300
Bass Boost @ 45Hz : 0~18dB
Signal to Noise Ratior : 105dB
Remote Gain Knob Included
Line Out RCA Connection
Mode Switch : Ch2/Ch4
Fuse Rate : 30 Amp x 2
4 Gauge Power & Ground Terminals
Dimensions : 350mm (Length) x 241mm (Width) x 64.5mm (Height)
3. Description/Condition:
Maybe a scratch here and there mounting points are a bit scratched. Works perfectly.
4. Price: :
175 shipped obo
5. Pictures:
419
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
925
842
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
Fireitup
Fireitup
Alabama
Fireitup
    Apr 26, 2024
    Apr 26, 2024
