D4 Audiomobile EVO-R 2312 (TC-9)
Flawless, barely used with about ten hours on it. Very rare driver. Relatively efficient and my ear tells me this has a shorting ring. Loud, low and clean.
Thiele / Small Parameters
Frequency Response (+ 2 dB) 20 – 600 Hz.
Sensitivity SPL (2.83V/1m) 89 dB
Impedance (Nominal) 8 / 2 Ohm
Re VC (ohms) parallel / series 1.5 / 6.2
Continuous Power (RMS) 750 Watts
RMS amplifier ("Musicpower") 1,500 Watts
Minimum Power (RMS) 200 Watts
Resonant Frequency (Fs) 24 Hz.
Qms 3.2
Qes .39
Qts .35
Vas (Cu. ft./L) 2.0’ / 59 L
Maximum Excursion (Peak-to-Peak) 60 mm
'X-MAX' (Linear one-way ) 27 mm/ 1.06”
BL (Tesla / M) 22.1 TM
Sd / per LMS (Sq. In./ Sq. M) 77 / .050
Mmd 195 g
Voice Coil Diameter 3.0”
Driver Weight 32 lbs.
$250 shipped, CONUS.
CONUS only, please.
Please check out the link for pictures, from the sale of its twin. This driver is in the exact same condition but I will gladly post a dated pic of this driver for serious inquiries.
http://www.caraudio.com/forums/subwoofer-classifieds/565650-bnib-tc-sounds-audiomobile-evo-r-12-d4.html
Qms 3.2
Qes .39
Qts .35
Mmd 195 g
CONUS only, please.
