Phoenix Gold TI1600.5
bdub77
Phoenix Gold TI1600.5 1200 Watt system amp
5-channel system amp by Phoenix Gold. There is a slight surface scuff on the top casing and a few marks on the mounting feet, otherwise it's perfect.
Power specs are:
Front and rear channels: 100W X 4 at 4 ohms
Sub channel: 800W X 1 at 2 ohms/1000 W X 1 at 1 ohm
See here for manual and full specs: http://www.phoenixgold.com/images/manuals/ti16005_manual.pdf
$500 shipped.
See above. Thanks.
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
585
I just read the other post about this Bass Cube. IMO, it sounds like a signal leveler with adjustable Q. For that you can just use one of the many...
  • Locked
You said, "one of." How many do you have? I'm guessing that you are keeping the best one(s).
5K
bdub77
bdub77
Coquitlam, BC
BEAST460
    May 10, 2024
3toneEYZ
    May 10, 2024
