4 dc xl m2 15s d1
  • 4
joshy629
4 dc xl m2 15s d1
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• Quad 8"OD semi cup progressive roll spiders
• Dual Extra heavy duty interweaved tinsel lead wire
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly – Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 0.7, 1.0, 1.4 or 2 ohm 3" 8 Layer Hi-temp Aluminum Stealth Coil
10" 12" 15" 18"
Mounting Depth 6.5" 7" 8.25" 9.25"
Mounting Hole Diameter 9.25" 11" 14" 16.75"
Outside Driver Diameter 11.0" 12.5" 15.7" 18.5"
Motor Width 8.75" 8.75" 8.75" 8.75"
Weight 53lbs 54lbs 56lbs 57lbs
VC Diameter 3" 3" 3" 3"
Displacement .18³ ft .19³ ft .23³ ft .26³ ft
Magnet Weight 50lbs 50lbs 50lbs 50lbs
Power Handling RMS/Peak 2200/4400 2200/4400 2200/4400 2200/4400
Impedance (Ohm) D.7/D1/ D1.4/D2 D.7/D1/ D1.4/D2 D.7/D1/ D1.4/D2 D.7/D1/ D1.4/D2
Sd 314.00 cm² 494.00 cm² 791.00 cm² 1159.00 cm²
Vas 12.42 liters 25.77 liters 66.02 liters 144.36 liters
Cms 0.085 mm/N 0.08 mm/N 0.07 mm/N 0.07 mm/N
Mms 171.77 g 213.7g 306.7 g 346.7 g
Fs 41.7 38.5 34.3 32.3
BL BL 22.73 N/A
22.73 N/A 22.73 N/A 22.73 N/A
Re 3.98 Ohm 3.98 Ohm 3.98 Ohm 3.98 Ohm
Le 5.2mH 5.2mH 5.2mH 5.2mH
Qms 11.24 12.92 16.55 17.6
Qes 0.35 0.403 0.516 0.548
Qts 0.34
0.391 0.5 0.532
Xmax 26 mm 26 mm 26 mm 26 mm
Ref SPL @ 1 watt 85.9 dB
87.5 dB 89.0 dB 91.3 dB
Suggested Sealed N/A N/A N/A N/A
Suggested Ported 1³ ft 1.5³ ft 3.5³ ft 6³ ft
3 are in perfect condition but one has 2 marks on the surround (see pictures)
ive only sent 4900 rms to all 4 so 1225 roughly a piece and they are rated 2200 each daily so these are barely even pushed to what they can do!!!
no marks on the spiders everything is in perfect shape except the rub marks you see on the ONE sub below
1700 shipped for all 4 in the us.
450 plus shipped if bought 1 at a time
400 SHIPPED FOR ONE WITH MARKS ON IT
and 950 shipped for A pair
NO TRADES NEED MONEY FOR MY NEW CAR SO PLEASE DONT ASK OR OFFER
FIND THE AMP IN THE AMP SECTION
1ST RUB MARK
2ND RUB MARK. BOTH MARKS ARE ON THE SAME SUB. OTHER 3 IN GREAT SHAPE
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
846
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
748
You may need to go to some shows and sound offs/meetings
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
joshy629
joshy629
lawrenceburg ky
joshy629
    Apr 26, 2024
    Apr 26, 2024
