kicker amps
  • 6
368
900
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
MrMckie
MrMckie
Hartford, CT
MrMckie
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
