Alpine 9887 CD problems
  • 2
UMWDawg92
Missoula, MT
So I recently picked up an Alpine 9887 and I when I got it hooked up I popped a CD in to test it out and it reads error. I figured oh it was a burned CD I'll try an original copy, same thing happens. So I try resetting it and different CD's finally get them to read but they play like they're being paused and unpaused continuously. If I turn it upside it improves but still not 100% right. Any ideas of what is wrong? Dirty laser? Or does it need repaired? Thanks
Are you trying regular CDs? It sounds like you're playing MP3 CDs which are encoded in a bit rate too high for the unit to decode.
yea I'm using regular CDs I even made sure to try out several original copies and several burned copies and keep getting the same thing
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
118
This weekend I will be taking actual pictures for other sites. So grab it before its gone
535
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
UMWDawg92
UMWDawg92
Missoula, MT
UMWDawg92
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
