Sell Johnny Drama any of the following
Trying to get back into audio doing an SQ build in my BMW. Need the following...
(2) 4" Component set (Mounting depth must be
See list below for some options/ideas of speakers that fit.
(2) 8" Subwoofer (Mounting depth must be
Amplifiers (I need any of the following combinations, however they must be matching amps or 1 large amp)
1)4x50-150 rms @ 4ohm, 2x150-200 @ 2 or 4 ohm, 900-1500 rms @ 1 or 4 ohm
2)8x50-150 rms @ 4ohm, 900-1500 rms @ 1 or 4 ohm
3)Suggest what you have. Remember I have 2 comp sets and 2 subs that need powered plus I have a 12" sub in the trunk.
Some speakers/comps/subs that will for sure fit in my car
4" component systems:
- Morel Dotech Ovation 4
- Top Mount Depth: 50 mm
- Bottom Mount Depth: ?
- Product Link: / Morel Dotech Ovation
- Installation Link: My aftermarket upgrade - Ultra permiu, sound + XM for LESS than A single BMW option. - BMW 3-Series (E90 E92) Forum - E90Post.com
- Morel Hybrid Ovation II 4
- Product Link: Morel Dotech Ovation
- Installation Link: http://farm3.static.flickr.com/2566/4123410471_303fe199dc.jpg
- BSW Stage I
- Top Mount Depth: ?
- Product Link: BMW Speakers Upgrade for BMW 3 Series 06+ (E90) | BSW
- Focal 100KRS / 100KP
- Top Mount Depth: 39 mm
- Bottom Mount Depth: 44 mm
- Product Link: http://www.focal-fr.com/catalogue-docs/EN/14/files/1761.pdf
- Installation Link: BMW 3-Series (E90 E92) Forum - View Single Post - Replacement speakers that fit?
- Focal 100VRS
- Top Mount Depth: 40 mm
- Product Link: http://akamaipix.crutchfield.com/Manuals/091/091100VRS.PDF
- Installation Link: My Hifi system upgrade. - BMW M3 Forum (E90 E92)
- Rainbow SLC 210.25 NG
- Top Mount Depth: 46 mm
- Product Link: rainbow - german car audio | Rainbow Audio Components
- Installation Link: 2011 Audio Upgrade Completed, Summery, Overview and Photos - BMW 3-Series (E90 E92) Forum - E90Post.com
- Rainbow CS 210 Vanadium
- Rainbow CS 210 Profi
- DLS PSA/PS4A
- Product Link: Reference PS4/PS4A - 2-way components 4 inches
- MB Quart RUA 210
- Top Mount Depth: 32 mm
- Product Link: http://www.maxxsonics.net/manuals/mbquart/pdfs/rua_210.pdf
- MB Quart RVF 210
- Product Link: http://www.maxxsonics.net/manuals/mbquart/pdfs/rvf_210.pdf
- Diamond Audio HEX S400*
- Product Link: http://www.diamondaudio.com/manuals/hex_speaker_manual-2008.pdf
- Renaissance SR-4.2
- Product Link: Renaissance Audio Group
- Note: Tweeter may not fit OEM pods
- Zapco CK-10.2
- Top Mount Depth: 48.25 mm
- Product Link: http://www.zapco.com/prod/Speakers/Documents/CK-10.2.pdf
- Helix P234 (aka H234 / HXS Precision [old model])
- Top Mount Depth: 47 mm
- Product Link: http://www.audioaffinityusa.com/helixsite/08/helix_precision_compspeakers08.htm
- Installation Link: DIY front door speaker mounting adapter - BMW 3-Series (E90 E92) Forum - E90Post.com
5.25" Component Systems:
- DLS Reference RS5/RS5A
- Top Mount Depth: 45 mm
- Product Link: Reference RS5/RS5A - 2-way kit 5,25 inches
- Boston Acoustics S50
- Product Link: High Performance Car Audio, Full Range Speakers, Amplifiers, and Subwoofers - Boston Acoustics
- MB Quart RUA 213*
- Top Mount Depth: 42 mm
- Product Link: http://www.maxxsonics.net/manuals/mbquart/pdfs/rua_213.pdf
- Installation Link: http://www.e90post.com/forums/attachment.php?attachmentid=325545&stc=1&d=1258132444
- Note: Requires dremeling speaker frame to fit inbetween OEM mounting screws
- Focal 130 VRS
- Top Mount Depth: 48.5 mm
- Bottom Mount Depth: 53 mm
- Product Link: http://www.focal-fr.com/catalogue-docs/EN/15/files/1304.pdf
And while I'm at it, might as well list the possible woofer replacement drivers for under the seats:
8" Woofers under Front Seats
- Earthquake SWS-8 / SWS-8X (4/2 ohm)
- Top Mount Depth: 2 1/8"
- Product Link: SWS The Original Shallow Woofer
- Installation Link: SWS 8 upgrade with MTX amp! - BMW 3-Series (E90 E92) Forum - E90Post.com
- Note: This is a sub-woofer, not a midbass driver! (mid-bass can be made to sound OK with digital processing)
- Hertz Space 8*
- Product Link: http://www.hertzaudiovideo.com/Doc/SchedaTecnica_space.pdf
- Installation Link: 2009 M3 with custom Audio, radar, and laser system - BMW M3 Forum (E90 E92)
- Note: Best used as midbass driver (bandpassed)
- Morel ADMW SW 9
- Top Mount Depth: 71 mm
- Product Link: Morel Loudspeakers - Mobile Audio - Subwoofers - ADMW SW
- Installation Link: Install fail, and our repair, in a 1-series (image intensive) - BMW 3-Series (E90 E92) Forum - E90Post.com
- Note: Best used as midbass driver (bandpassed). Requires 3/4" spacer ring and Morel grille to protect cone & surround from floor carpet.
- Kicker SSMB8* (Thanks Technic!)
- Top Mount Depth: 59 mm
- Product Link: Kicker SSMB8 SS Series 8" midbass speakers at Crutchfield.com
- Installation Link: BMW 3-Series (E90 E92) Forum - View Single Post - Aftermarket Replacement Speakers List
- Note: According to Technic, much better midbass driver than SWS-8, but not as good at sub-bass frequencies (30-40Hz), i.e. you will need an additional sub. Requires 1/2" spacer ring to fit enclosure and 1/4" shim underneath OEM grilles. Carpet needs to be cut away under seat rails to prevent surround hitting it but looks stock once seats installed.
- Jehnert XE 200
- Product Link: Jehnert woofer
- Note: Requires spacers (thickness unknown). Manufacturer recommends the use of a subsonic filter starting at 80 Hz, suggesting this driver is optimized for mid-bass ("kick bass") and perhaps not well suited for sub-bass.
- Morel MW 265-4
- Top Mount Depth: 69 mm
- Product Link: https://www.madisound.com/store/product_info.php?products_id=613products_id613
- Installation Link: BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i) - View Single Post - 2011 Base Stereo Upgrade
- Note: Requires spacers (min. 3/4" thick but may vary depending on car and model year).
- Renaissance WR-8
- Note: Dimensions seem to be identical to the Morel MW265-4. I am still checking to see if there are any substantial differences between the two. This driver has a very high power handling (200W) and a very low resonant frequency (30Hz) so it can almost be used like a subwoofer. Requires spacers (min. 3/4" thick but may vary depending on car and model year).
* may no longer be available new, so check eBay.
QUOTE]
I have some never installed Morel MW-267's you might be interested in...
Ram, I looked at those over on SSA when you posted them. From what I can tell of them, are they not better in the 50-800Hz range rather than sub bass duty?
Hifonics Series VII Gemini 50x4@4ohms Hifonics Series VII Zeus 900x1@4ohms $500/shipped for the pair
Thanks for the offer, but Im going to pass on these. If I were going to run hifonics they would need to be from the late 90s.
i have a pretty much brand new set of 4" Boston Rally componets
Googling specs...Ill PM you if Im interested. Can you confirm they are the Boston Rally RC420?
i also have an original MB Quart 8" 3way componet set bnib...not sure of mounting depths a very high end set...German made not maxxsonic crap
Now Id love to have these, but the 8" locations are underneath the rear seats. This would **** for any mid-bass speakers. Its really only ideal for subwoofers. I will however think it over and do some searching on them. Like above Ill PM you if I can use them.
They're actually very similar to the MW-265 and WR-8 that you have in the original post, just more recent and upgraded. Slightly more xmax, power handling, motor strength and a gs in the mid 20's.
I am building and selling the subs. Like to get input on if basket colors options would be a winner. I do custom painting on guns already.
998
power_turd
Banned
power_turd
yOUR lITTLE sISTER's hOUSE
CerwinVega_Fan
    Apr 26, 2024
    Apr 26, 2024
