Trying to get back into audio doing an SQ build in my BMW. Need the following...
(2) 4" Component set (Mounting depth must be
See list below for some options/ideas of speakers that fit.
(2) 8" Subwoofer (Mounting depth must be
Amplifiers (I need any of the following combinations, however they must be matching amps or 1 large amp)
1)4x50-150 rms @ 4ohm, 2x150-200 @ 2 or 4 ohm, 900-1500 rms @ 1 or 4 ohm
2)8x50-150 rms @ 4ohm, 900-1500 rms @ 1 or 4 ohm
3)Suggest what you have. Remember I have 2 comp sets and 2 subs that need powered plus I have a 12" sub in the trunk.
Some speakers/comps/subs that will for sure fit in my car
4" component systems:
- Morel Dotech Ovation 4
- Top Mount Depth: 50 mm
- Bottom Mount Depth: ?
- Product Link: / Morel Dotech Ovation
- Installation Link: My aftermarket upgrade - Ultra permiu, sound + XM for LESS than A single BMW option. - BMW 3-Series (E90 E92) Forum - E90Post.com
- Morel Hybrid Ovation II 4
- Product Link: Morel Dotech Ovation
- Installation Link: http://farm3.static.flickr.com/2566/4123410471_303fe199dc.jpg
- BSW Stage I
- Top Mount Depth: ?
- Product Link: BMW Speakers Upgrade for BMW 3 Series 06+ (E90) | BSW
- Focal 100KRS / 100KP
- Top Mount Depth: 39 mm
- Bottom Mount Depth: 44 mm
- Product Link: http://www.focal-fr.com/catalogue-docs/EN/14/files/1761.pdf
- Installation Link: BMW 3-Series (E90 E92) Forum - View Single Post - Replacement speakers that fit?
- Focal 100VRS
- Top Mount Depth: 40 mm
- Product Link: http://akamaipix.crutchfield.com/Manuals/091/091100VRS.PDF
- Installation Link: My Hifi system upgrade. - BMW M3 Forum (E90 E92)
- Rainbow SLC 210.25 NG
- Top Mount Depth: 46 mm
- Product Link: rainbow - german car audio | Rainbow Audio Components
- Installation Link: 2011 Audio Upgrade Completed, Summery, Overview and Photos - BMW 3-Series (E90 E92) Forum - E90Post.com
- Rainbow CS 210 Vanadium
- Rainbow CS 210 Profi
- DLS PSA/PS4A
- Product Link: Reference PS4/PS4A - 2-way components 4 inches
- MB Quart RUA 210
- Top Mount Depth: 32 mm
- Product Link: http://www.maxxsonics.net/manuals/mbquart/pdfs/rua_210.pdf
- MB Quart RVF 210
- Product Link: http://www.maxxsonics.net/manuals/mbquart/pdfs/rvf_210.pdf
- Diamond Audio HEX S400*
- Product Link: http://www.diamondaudio.com/manuals/hex_speaker_manual-2008.pdf
- Renaissance SR-4.2
- Product Link: Renaissance Audio Group
- Note: Tweeter may not fit OEM pods
- Zapco CK-10.2
- Top Mount Depth: 48.25 mm
- Product Link: http://www.zapco.com/prod/Speakers/Documents/CK-10.2.pdf
- Helix P234 (aka H234 / HXS Precision [old model])
- Top Mount Depth: 47 mm
- Product Link: http://www.audioaffinityusa.com/helixsite/08/helix_precision_compspeakers08.htm
- Installation Link: DIY front door speaker mounting adapter - BMW 3-Series (E90 E92) Forum - E90Post.com
5.25" Component Systems:
- DLS Reference RS5/RS5A
- Top Mount Depth: 45 mm
- Product Link: Reference RS5/RS5A - 2-way kit 5,25 inches
- Boston Acoustics S50
- Product Link: High Performance Car Audio, Full Range Speakers, Amplifiers, and Subwoofers - Boston Acoustics
- MB Quart RUA 213*
- Top Mount Depth: 42 mm
- Product Link: http://www.maxxsonics.net/manuals/mbquart/pdfs/rua_213.pdf
- Installation Link: http://www.e90post.com/forums/attachment.php?attachmentid=325545&stc=1&d=1258132444
- Note: Requires dremeling speaker frame to fit inbetween OEM mounting screws
- Focal 130 VRS
- Top Mount Depth: 48.5 mm
- Bottom Mount Depth: 53 mm
- Product Link: http://www.focal-fr.com/catalogue-docs/EN/15/files/1304.pdf
And while I'm at it, might as well list the possible woofer replacement drivers for under the seats:
8" Woofers under Front Seats
- Earthquake SWS-8 / SWS-8X (4/2 ohm)
- Top Mount Depth: 2 1/8"
- Product Link: SWS The Original Shallow Woofer
- Installation Link: SWS 8 upgrade with MTX amp! - BMW 3-Series (E90 E92) Forum - E90Post.com
- Note: This is a sub-woofer, not a midbass driver! (mid-bass can be made to sound OK with digital processing)
- Hertz Space 8*
- Product Link: http://www.hertzaudiovideo.com/Doc/SchedaTecnica_space.pdf
- Installation Link: 2009 M3 with custom Audio, radar, and laser system - BMW M3 Forum (E90 E92)
- Note: Best used as midbass driver (bandpassed)
- Morel ADMW SW 9
- Top Mount Depth: 71 mm
- Product Link: Morel Loudspeakers - Mobile Audio - Subwoofers - ADMW SW
- Installation Link: Install fail, and our repair, in a 1-series (image intensive) - BMW 3-Series (E90 E92) Forum - E90Post.com
- Note: Best used as midbass driver (bandpassed). Requires 3/4" spacer ring and Morel grille to protect cone & surround from floor carpet.
- Kicker SSMB8* (Thanks Technic!)
- Top Mount Depth: 59 mm
- Product Link: Kicker SSMB8 SS Series 8" midbass speakers at Crutchfield.com
- Installation Link: BMW 3-Series (E90 E92) Forum - View Single Post - Aftermarket Replacement Speakers List
- Note: According to Technic, much better midbass driver than SWS-8, but not as good at sub-bass frequencies (30-40Hz), i.e. you will need an additional sub. Requires 1/2" spacer ring to fit enclosure and 1/4" shim underneath OEM grilles. Carpet needs to be cut away under seat rails to prevent surround hitting it but looks stock once seats installed.
- Jehnert XE 200
- Product Link: Jehnert woofer
- Note: Requires spacers (thickness unknown). Manufacturer recommends the use of a subsonic filter starting at 80 Hz, suggesting this driver is optimized for mid-bass ("kick bass") and perhaps not well suited for sub-bass.
- Morel MW 265-4
- Top Mount Depth: 69 mm
- Product Link: https://www.madisound.com/store/product_info.php?products_id=613products_id613
- Installation Link: BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i) - View Single Post - 2011 Base Stereo Upgrade
- Note: Requires spacers (min. 3/4" thick but may vary depending on car and model year).
- Renaissance WR-8
- Note: Dimensions seem to be identical to the Morel MW265-4. I am still checking to see if there are any substantial differences between the two. This driver has a very high power handling (200W) and a very low resonant frequency (30Hz) so it can almost be used like a subwoofer. Requires spacers (min. 3/4" thick but may vary depending on car and model year).
* may no longer be available new, so check eBay.
QUOTE]
