Dual 15" Kicker L7 install, Pics included!
DarkFox
Well, I posted the box build along time ago and finally got the system in. here are the pics from it. i am really pissed I couldn't get more pics (like when it was finished) but the my friend had just got out of the military and we had to get it done so he could go home. I was REALLY SICK and had to do the whole thing in 3 days in 110+ degree weather. Anyway, here is what I got.
Front doors
Rear crossovers inside rear door speaker pod
Finished rear door pods:
Rear Battery install:
Amp rack with cap:
It actually looks really nice in person. The top amp glows red and the bottom blue and after some adjustments those panels lined up nicely on the amp rack. He didn't listen to me when I told him to order carpet like 2 weeks ago... so no carpet on it. Let me tell you though.. It WANG'S HARD. He flex's his whole roof panel at least a inch.. Its crazy. Really wish I had a video. Like I said, I was sick when we set it up, and he originally was gonna get a XX-Colossus and was gonna wire it to two ohms. So when I hooked up the XX-Hercules I went on auto pilot and set up a series-parallel. It was loud then!!! Then I realized what I had done and was like dude.... Thats only 600W, pulled the subs out and re wired them for 1ohm mono and thats when the Wangage really began. Anyway, enjoy. Hope you like. Its really nice to me that the ONLY place you see wire on the whole install is
A. Under the hood
B. On the rear bat
C. the 1 inch next to the cap
Where the **** are the subs. //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Nice work though, far better than I could do. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
726
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
737
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
839
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
DarkFox
DarkFox
Old Lyme, CT
Flipx99
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
