Zed Leviathan 6channel V2
Krieger88
Cosmetic 9.5/10 Functionality 10/10 , Had to have 3 broken capacitors repaired by Zed and had the amp professionally tested before it was sent back to me.
$550 firm
I'll pay shipping
Item Pictures: View attachment 26544329View attachment 26544330
Amp Specs:
Continuous Output Power into 2 ohm: 300w x 6
Continuous Output Power into 4 ohm: 150w x 6
Typical Output Power into 4 ohm per channel (1% THD): 180w x 6
Continuous Output Power 3 pairs of channels bridged into 4 ohm: 600w x 3 Channel pairs may be bridged independently
Continuous Output Power 2 channels bridged into 8 ohm: 300w x 3 Channel pairs may be bridged independently
Minimum Speaker Impedance: 2 ohm per channel
Minimum Speaker Impedance in Bridge Mode (2 channels): 4 ohm
Power Response at any power into 4 ohms: 10-60KHz -2dB
Frequency Response at rated power into 4 ohms: 10Hz-30KHz -0.1dB
Input Voltage range for rated power into 4 ohms: 0.25 to 8.6 volt
Input Impedance at 2KHz: 47K ohm
Noise below rated output (30KHz limited): -100dB
Channel separation at 2KHz: >80dB
Damping Factor at 20Hz with 4 ohms: >80
Total Harmonic Distortion with 4 ohm 20Hz-20KHz
From 1 watt to rated power. Typically less than 0.05%:
Intermodulation Distortion:
Phase response at 20KHz: Lagging 12 deg
Slew rate (volts per micro second)-In”Flat” mode: 12
High Pass Crossovers (24dB/octave) Channels 1+2 and 3+4: 55Hz-4KHz
Low Pass Crossovers (24dB/octave) Channels 3+4: 55Hz to 4KHz
High Pass Crossovers (24dB/octave) Channels 5+6: 10Hz-105Hz May be used as a Sub Sonic Filter
Low Pass Crossovers (24dB/octave) Channels 5+6: 40Hz to 235Hz
Protection - Short Circuit, DC, Thermal: Yes
Power Source: 10-14.5v DC Negative Ground
Current Consumption with Sinewave at 4 ohms: 94A
Current Consumption with Music at 4 ohms: 18 to 28A
Idling Current:
Fuse rating with 4 ohm load: 30A-40A depending on usage
Fuse rating with 2 ohm load: 40A -80A depending on usage
Size W x H (247mmx55mm/9.7”x2.1”) x L: 410mm/16.14” Excludes connectors
Shipping Weight (Kg/Lbs): 5.9 / 13
Made in USA
  • Locked
I don't suppose you have a spare Zed mikro IV in your collection? I'm conveniently located in central Florida and have cash on hand, lol. Matt
Krieger88
Krieger88
Medford, ny
Krieger88
