xxv Sampson
ty_houston
I just got 2 of these for my h2 build. I know they are notorious for not being good in daily applications, my build should be done in about a month, and I'll let you know my experience with them, gonna strap them on 6 massive audio dmx 15's in a semi clamshell in my h2...each amp will be seeing 1.3 ohms dcr..electrical: 2 mechman 250 amp alts, dual mla mod(14.8/15.7 volts) 6 kinetik 2400's, I know I need more batts, get those income tax time, whenever its done I'll start a build log.....
Give me a call sometime after 5PM CST tomorrow by the way.
Sexy amps. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
ok, I'm going through drama getting my z2 from that repair shop I told you about, tell you about it tomorrow..
You'll probably be good with 8 hc2400's.
Correct me if I'm wrong but isn't it a bad thing to over charge your batts? Charging a 12v batt at 16v will do more harm than help right?
batts would charge at 15.7, Trust me with two sampsons it will not stay at 15.7. I would prolly charge it at 14.8 volts for every day use, the module in Chris's Hummer of MLA charges his 12 volt system at 16 volts with no problem and he has had his set this way over two years.
I thought so, just going off manufacture specs. 14.9+ voids the waranty. That's perfect for your setup, get that batt count up:D
ty_houston
ty_houston
Virginia Beach Virginia
SicAudio
