I'm selling my Xtant 121 Monoblock Amplifier. This thing is a beauty. I almost just want to keep it just to stare it, but I have some other expenses to take care of. Xtant produces sick stuff, for pretty insane prices. If you're a car audio geek, you know that Xtant is some high quality stuff. This is a mono amplifier, Class A/B, and can be used to power a subwoofer. The amp also has two module ports that can be used to connect crossovers, equalizers, etc. Everything is top shape, the amp works like a champ. Here are the specs:
Standard Features
Regulated, PWM MOSFET Switching Power Supply
Discrete MOSFET Output Circuitry
Mono Design
Selectable 90 Hz Low-Pass Crossover
Balanced Line Input Circuitry
40 dB of Input Sensitivity �½ Adjustable in 10 dB Steps
Two Accessory Module Ports
Low Impedance Protection with Diagnostic LED
Thermal Protection with Diagnostic LED
Designed, Engineered, and Handcrafted by Xtant in the U.S.A
Specifications:
Watts per Channel @ 4 Ohms: 1 x 125 Watts
Watts per Channel @ 2 Ohms: 1 x 250 Watts
Frequency Response: 5 Hz to 50 kHz
Distortion (THD):
Signal-To-Noise Ratio: > 100 dB
Damping Factor (@ 100 Hz into 4�½ load): > 200
Input Sensitivity
Unbalanced Source 100mV to 8.5V
Balanced Source 100mV to 17V
Output Impedance: 2 - 8 Ohms
Supply Voltage: 10.5 to 15 Volts
Fuse: 30 Amp
Dimensions: 11 x 1.8 x 8�½
I'm asking 100 bucks shipped. Let me know.
Standard Features
Mono Design
Specifications:
Distortion (THD):
Input Sensitivity
Fuse: 30 Amp
