xbox live with verizon fios
dvrmstrng
anyone set up their live with fios internet and the supplied router. I google searched everything and each different walk through seems to have different directions and none of them are working. Anyone have any suggestions here. As of right now the xbox is connected to the router via ethernet and when i log into my router it does not even see the xbox. Thanks in advance.
The xbox should ask you to put a password in that you have on your router. I have mind hook up wireless. So I had to put in the wep and password. But the xbox should do this auto for you. Odd. Im puzzled.
hmmm i had no issues with my two xbox's or ps3. i had issues setting up my laptop. did you use all the info off of the router? ie model # and passcode shit?
Is the xbox powered on and connected to an ethernet cable? Check the back of the xbox and see if you have any lights where the ethernet cable is plugged in. Also, depending on what kind of router you have, it should pick up a DHCP address so you shouldn't have to assign a manual IP.
dvrmstrng
dvrmstrng
DE
audioatg
