Always thought the PS# was the superior machine.. But The 360 has a better CPU , and full 1080p output , while the ps3 has a slightly better GPU.. Yes , im this bored today...
Xbox 360 Vs PS3: GPU Specs
Core Clock Frequency
Xbox 360 - 500 MHz
PS3 - 500 MHz
Triangle Setup
Xbox 360 - 500 Million Triangles/sec
PS3 - 250 Million Triangles/sec
Vertex Shader Processing (Vertex ALU x Clock / 4)
Xbox 360 - 6.0 Billion Vertices/sec (using all 48 Unified Pipelines)
Xbox 360 - 2.0 Billion Vertices/sec (using 16 of the 48 Unified Pipelines)
Xbox 360 - 1.5 Billion Vertices/sec (using 12 of the 48 Unified Pipelines)
Xbox 360 - 1.0 Billion Vertices/sec (using 8 of the 48 Unified Pipelines)
PS3 - 1.0 Billion Vertices/sec
Filtered Texture Fetch
Xbox 360 - 8.0 Billion Texels/sec
PS3 - 12.0 Billion Texels/sec
Vertex Texture Fetch
PS3 - 4.0 Billion Texels/sec
Pixel Shader Processing with 16 Filtered Texels Per Cycle (Pixel ALU x Clock)
Xbox 360 - 24.0 Billion Pixels/sec (using all 48 Unified Pipelines)
Xbox 360 - 20.0 Billion Pixels/sec (using 40 of the 48 Unified Pipelines)
Xbox 360 - 18.0 Billion Pixels/sec (using 36 of the 48 Unified Pipelines)
Xbox 360 - 16.0 Billion Pixels/sec (using 32 of the 48 Unified Pipelines)
PS3 - 16.0 Billion Pixels/sec
Pixel Shader Processing without Textures (Pixel ALU x Clock)
PS3 - 24.0 Billion Pixels/sec
Multisampled Fill Rate
Xbox 360 - 16.0 Billion Samples/sec (8 ROPS x 4 Samples x 500MHz)
PS3 - 8.0 Billion Samples/sec (8 ROPS x 2 Samples x 500MHz)
Pixel Fill Rate with 4x Multisampled Anti-Aliasing
Xbox 360 - 4.0 Billion Pixels/sec (8 ROPS x 4 Samples x 500MHz / 4)
PS3 - 2.0 Billion Pixels/sec (8 ROPS x 2 Samples x 500MHz / 4)
Pixel Fill Rate without Anti-Aliasing
Xbox 360 - 4.0 Billion Pixels/sec (8 ROPS x 500MHz)
PS3 - 4.0 Billion Pixels/sec (8 ROPS x 500MHz)
Frame Buffer Bandwidth
Xbox 360 - 256.0 GB/sec (dedicated for frame buffer rendering)
PS3 - 20.8 GB/sec (shared with other graphics data: textures and vertices)
PS3 - 10.8 GB/sec (with 10.0 GB/sec subtracted for textures and vertices)
PS3 - 8.4 GB/sec (with 12.4 GB/sec subtracted for textures and vertices)
Texture/Vertex Memory Bandwidth
Xbox 360 - 22.4 GB/sec (shared with CPU)
Xbox 360 - 14.4 GB/sec (with 8.0 GB/sec subtracted for CPU)
Xbox 360 - 12.4 GB/sec (with 10.0 GB/sec subtracted for CPU)
PS3 - 20.8 GB/sec (shared with frame buffer)
PS3 - 10.8 GB/sec (with 10.0 GB/sec subtracted for frame buffer)
PS3 - 8.4 GB/sec (with 12.4 GB/sec subtracted for frame buffer)
Shader Model
Xbox 360 - Shader Model 3.0+ / Unified Shader Architecture
PS3 - Shader Model 3.0 / Discrete Shader Architecture
Xbox 360 - 500 MHz
PS3 - 500 MHz
Triangle Setup
Shader Model
