WUT IS RCA and AUX
RCA is a type of connector. Most aftermarket head units use RCA type connections for preamp outputs, so when someone mentions RCA outputs, they usually mean the preamp outputs.
AUX usually means Auxillary input, which allows you to use an external source with your head unit.
ok..well what is the difference between 1 RCA preout and 2 RCA preouts.SOme HU has 1 RCA and some have 2 RCA.What is the difference,explain me please.Is there a MAJOR difference or not.
Typically we run front preouts into an amp for our front speakers, and the rear set goes to an amp for subs. Having only 1 set is somewhat limiting, but not the end of the world. Head units with only 1 set are usually shitty cheap ones, or stock factory units. I wouldn't buy one.
BADSECTOR
BADSECTOR
Hard disk,PC
maylar
