WTT Sperry DSA-500 Clamp DMM
Here2Learn
I be done did dat...
What ya got? 7/10 cosmetically
This affordable, lightweight and durable snap-around volt-amp meter will rival more expensive meters, but at a much lower price. AC current, AC & DC voltage, resistance and continuity readings are easily taken.
Despite its low price, useful features are not lacking-it is UL listed, has an electronic overload protector, data hold button, sleep functions and continuity buzzer.
Features:
DC Voltage and AC Voltage Ranges
Continuity Buzzer
Overload Protection on All Ranges
Overvoltage category III 300V, pollution degree 2
Overvoltage category II 600V, pollution degree 2
Data Hold
Includes Industry Standard Safety Probes
2 Recessed Safety Designed Input Terminals
Sleep feature to extend battery life
Lifetime Limited Warranty
Spec Summary:
Withstand Voltage: 3,700VAC (RMS, 50/60Hz) for 1 minute between electrical circuit and housing case.
Insulation Resistance: 10M Ohm or greater at 1,000V between electrical circuit and housing case.
Dimensions:7"L x 1.75"W x 1.1"D (184 x 44 x 27mm)
Weight: Approx. 7 oz (190g) including batteries
AC Current
Ranges: 40A (0-39.99A)
Ranges: 400A (0-399.9A)
Basic Accuracy: ±2.0%rdg ±6dgt (50/60Hz)
AC Voltage
Ranges: 400V (0-399.9V)
Ranges: 600V (150-599V)
Basic Accuracy: ±2.0%rdg ±5dgt (50/60Hz)
DC Voltage
Basic Accuracy: ±1.5%rdg ±5dgt
Resistance
Ranges: 400 Ohm (0-399.9 Ohm)
Ranges: 4,000 Ohm (150-3999 Ohm)
That thing doesn't even do DC current... What good is it to most people on this forum? Sorry to be an a$$ but just pointing that out before someone gets mad that they can't do DC current. Not a bad meter besides not being able to do that though.
and? it does DC voltage...sperry is a TOP OF THE LINE DMM...how many DMM do DC current anyways dick
Fluke fyi. I wasn't knocking the meter at all... Just usually someone get's a clamp meter for doing current in which most people on this forum would want to buy that meter to do current and also want to do DC current.. Hence this is a 12volt forum. c0ck
Here2Learn
Here2Learn
Unknown Parts
htownplaya456
