WTT orion hcca subwoofer
michaellane
well I got it in a trade. its a dual 2ohm 10" and was only used for a few months. would like to trade for: nice HU, more subs, amp or kinetik batts (sp?)....that's about it...
will get pics up tomorrow as im posting from my phone...
please post mod number, specs and a pic of item being offered.
thanks
are orion subs good?
junk... J/K
* Sensitivity: 84 dB
* RMS Power Range : 1500 Watts
* Peak Power Handling: 3000 Watts
* Impedance: 4 Ohm
* Diameter: 10 Inch
Features:
* 4" copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
* Continuous power handling will be 1500W (under rated)
* X-Max estimated at 30mm (total travel 4� peak to peak)
* Field Replaceable Cone / Voice coil / Spider Assembly
* Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
* Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
* Enhanced voice coil cooling system (forced convection � aluminum heat sinking � shorting rings to reduce inductive heating)
junk... J/K pretty sure this is a 4" coil....
3" //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif as far as i know. but still 10" sub with 3" coil isnt too shabby
edit: guess i was wrong //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif 4" coil
michaellane
michaellane
tx
michaellane
