WTT: New Condition Opti6000D for RF T40001bd
us3
Hi
I bought this amp BNIB and have only taken it out of the box twice. (once for the pics and once for a light daily test)
It is in like new condition and will trade with everything it did new. It will arrive exactly as shown. (please see pics)
This is a Great Amp but I need a RF T40001bd to link with another one that I have so I'm unfortunately having to offer it for trade.
Please post or email for Any Questions or Offers. I'll list the Mfj's Spec's, some rough daily info and pics of the amp:
Mfj Spec's
1 x 3000 Watts RMS @ 4 OHMS
1 x 4000 Watts RMS @ 2 OHMS
1 x 6000 Watts RMS @ 1 OHM
Mono Block Subwoofer BIG POWER Amplifier
1 Ohm Stable
MOSFET Power Supply
PWM(Pulse-Width-Modulated) System
Glass Epoxy PCB
Gold plated RCA Inputs
Gold plated Line outs
Custom Terminal Block for Speaker Connections
Thermal,Overload Short Protection
Variable Low pass Filter (50Hz~150Hz,24dB/Octave)
Variable Subsonic Filter (15Hz~40Hz,24dB/Octave)
Phase Control 0-180 degree
Remote Bass Control
Input Impedance:10K Ohms
Soft Turn On/Off
THD: 0.1%.
S/N Ratio: 90B
Input Sensitivity: 200mv~4V
Freq. Response: 20Hz~250Hz
Dimensions :10.08'' (W) x 2.12'' (H) x 27.6'' (L)
I tested this amp @ just under 3000wrms @ over 2 ohms @ under 11v so the amp can truly make the power at all levels!!!
(I heard with higher voltages and lower imp's, it just keeps making more and more power..)
Want To Trade: for good condition RF T40001bd
Please let me know what you have and we can see about working out a trade.
wow, thats an impressive amp, do you happen to have the birthsheet? im curious to see what it says...
Hi
These amps do not come with birth sheets but it's a similar amp to the SS XXX10000D so that may give an idea of the capability. (it actually had more caps that the SS too)
Sorry they didn't provide a sheet to show.
Matt
That is a Soundstream 6500d board. Dose not mean its the same amp.
It's actually longer than the 6500d, do a little reaserch on it.
And yes it is a different amp than either of the XXX's
Thanks for the bump though
Matt
WHOA WHOA!!! I was thinking about doing this trade...buttttt
If this is the same board as a SoundStream XXX6500D... Then its the same board as a Audiobahn A4KDN. Now I know that the SS and Audiobahn use the same internals. But if this is the case, then NO way does this amp put out 6000 rms @1 ohm @ 12volts
Another thing.. the amp says.."Designed and Manufactured in the USA"...but on the box it says "Made In Korea"..?!?!?!?!??!
Man,
You guys need to do some more research on your amps before you look into buying or trading them.
The Opti4000D is similair to the SS XXX6500
and the Opti6000D id similair to the SS XXX10000
Take a look on ROE and there are plenty of posts, pics and info about all these amps..
I don't mind the bumps but please get the facts strait before posting.
Thanks
Matt
Man,
Thanks
Matt
x2
Correct, I was wrong, I dont know what i was thinking. I got the models mixed up. This amps will do close to specs on the right electrical system. Look it up people. Someone did a full test and review on here. Good amp free bump.
Man,
Thanks
Matt
designed and engineered in the united states
us3
us3
San Diego
us3
