Trancer
I have a Phoenix Gold Tantrum 500.2 that does well over rated power.
What I am looking for.
I am looking for a quality 4 channel amp that does atleast 125wrms x 4 @ 4 ohms. I'd prefer 150wrms+ x 4 @ 4 ohms. Im not looking for crappy amps. This Tantrum is a top of the line amp so dont send me crappy amps, please.
I would really be interested in a Phoenix Gold tantrum 600.4.
Specs:
Designed with an emphasis on earth shattering power, and exceptional sound quality through advanced engineering and efficient production technologies, the new Tantrum series amplifiers from Phoenix Gold break the barrier in affordable, high end car audio. In fact, every aspect of this line is new from the ground up! While affordability typically means sacrificing high performance features, the Tantrum series breaks new ground with its built-in options. For superior sound reproduction, the Tantrum 500.2 amplifier feature an internal, defeatable 18dB per octave crossover and is equipped with inputs that can be connected directly to a high power head unit for greater versatility. This series also offers an adjustable 18 dB Bass Boost at 45 Hz for that slam in your face bass. These amplifiers handle the demands of a high performance mobile audio system with maximum power and dependability. The PWM Mosfet power supply commands maximum output, even under intense heat, while the new thermally efficient heatsink design supplies improved thermal dissipation. This, combined with the built-in overload and thermal protection circuitry, provides safe and reliable performance. LPL wired Low Pass Level control is optional.
Please note that Phoenix Gold amplifiers and speakers are only shipped to destinations within USA.
Key Features:
Thermally Efficient Heatsink
Timed Acoustically Integrated Muting (TAIM)
Differential RCA or Speaker Level Inputs
Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
18dB / Octave High Pass or Low Pass Crossover
40Hz to 800Hz Continuously Variable Crossover Frequency
Auxiliary Outputs Route Inverse Crossover Signals
Variable Twin-"T" Bass EQ Circuit Provides Up to 18 dB of Boost at 45 Hz
Optional RMD Remote Monitoring Display Port
Optional LPL Low Pass Level Controller Allows for Driver's Seat Adjustment of Bass Volume
Amplifier Type: 2-channel
RMS Power: 125W x 2 @ 4 ohms
RMS Power: 250W x 2 @ 2 ohms
Bridged RMS Power: 500W x 1 @ 4 ohms
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Specs:
Key Features:
Preamp Outputs: Yes
