WTT: MTX and Planet Audio Amp for Computer Equipment
midnightg35x
RF Amp Design Engineer
I have 2 amps I repaired to trade. I am looking to trade for a dual core (any kind) desktop with SATA II. Monitor not required as this will become a server.
Also entertaining regular sale if someone wants the amps without trade. Both amps were repaired by me and verified to 25W output on each channel. Beyond 25W the speaker I tested with started smoking and I only had a 10A power supply. Both are working 100% as the oscilloscope screenshots will show.
Amp 1: MTX Thunder 4202
http://www.mtx.com/caraudio/archive/thunder4202.cfm
Specifications
Power 12.5 VDC Input
2 Ohm Load 100 w x 2 Low Level
4 Ohm Load 50 w x 2 Hi Level w/ Smart Engage
Bridged 4 Ohm Load 200 w Crossover(s)
Power 14.4 VDC Hi / Low @ 85Hz
2 Ohm Load 140 w x 2 Fixed, Defeatable
4 Ohm Load 85 w x 2 RCA Output
Bridged 4 Ohm Load 280 w Full Range Only
Dimensions
(with ISO Feet)
9.3" x 9.75" x 2.1"
23.6cm x 24.8cm x 5.3cm
Left Channel:
Right Channel:
Amp 2: Planet Audio PA3002
Made in the USA
PA3002 User Manual
150W RMS x 2 @ 4 ohm
Left Channel:
Right Channel:
midnightg35x
midnightg35x
Iowa
midnightg35x
