WTT Kenwood amp+cash for 1200watt at 1ohm
Ledoux289
I've got a Kenwood 9104D that is pretty much NIB. It's got a piece of plastic broken off around the ground connection, purely cosmetic. It's never seen power. After purchasing the amp I've been reading that it really can't run at 1 ohm, so it's still good for 900 watts at 2 ohm. I've been trying to pull the trigger on just buying another amp in the 1200 watt range, butt can't do it because I've just got this one sitting here. If anyone is interested in it I'd throw some cash on top of it for an amp that runs 1000 to 1200 watts at 1 ohm.
The specs on the 9104D are:
• 1800 Watts Maximum Output Power with 30% Smaller Chassis Size
• 500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
• 1-ohm stable (output regulated to 900 Watts)
• Variable low-pass filter (50-200 Hz at -24 dB per octave)
• Bass Boost Control (0-18 dB at 40 Hz)
• Subsonic filter (15/25 Hz, 18 dB/octave)
• Class D design
• Speaker-level inputs with signal sensing turn-on
• Preamp-level inputs and outputs
• Fuse rating: 30A x 2
• 13-11/16"W x 2-3/8"H x 9-5/16"D
how much cash are you looking to spend?I have 2 amps you might be interested in.brand new rockford fosgate power T10001bd rated at 1000 watts rms,birth sheet ran 1360 rms at 1ohm,and I got a mtx ta81001d,rated at 1500 rms.lmk,thanks
I went ahead and bought an amp that should run my subs nicely. So this thread can be closed. I'll start a for sale thread for the amp at a later time. Thanks.
Ledoux289
Ledoux289
San Antonio
Ledoux289
