1. Product: JVC EXAD(KW-AVX800)
2. Specs -
Power Output: 50W x 4 Max.
MOS-FET Power Amp
Built-in 7-Inch Wide Touch Panel Monitor
USB Port (Rear)
SD Card Slot - JPEG / WAV / AAC* / MP3 / WMA Playable
GIGA MP3 MULTI
AAC* / WAV / MP3 / WMA Compatible (DVD/CD/USB)
DivX® / JPEG / MPEG1, 2 Compatible (DVD/CD/USB)
DVD Audio Compatible
7-Band iEQ
Ready for Bluetooth Adapter**
Ready for iPod*** SAT Radio Ready**** 108MHz / 12-bit Video DAC
5.1-Channel DTS / 5.1-Channel Dolby Digital / Dolby Pro Logic II/MPEG Audio
192kHz / 24-bit Audio DAC
Time Alignment (5.1ch)
J-BUS Terminal
5V Line/Subwoofer Output Level
Gold-Plated AV Output Terminals (Front / Rear / Center / Subwoofer / Video)
Gold-Plated Second Audio Output Terminals
Gold-Plated AV Input Terminals
Video Input Terminals for Camera
Motorized Slide-Out Face
Easy-Grip Wireless Remote Control
Dual Zone Function
Head Phone Surround
Shock Proof Memory
Wall Paper Setting
Amp Defeat Switch
Tel. Muting
Steering Remote Control Ready
Rear-View Camera ReadyDVD Player Section
Frequency response16 - 22,000Hz (DVD fs=48kHz)
16 - 88,000Hz (DVD fs=192kHz)
16 - 20,000Hz (CD)Dynamic range93dB (fs=48kHz)Signal-to-noise ratio95dB (fs=48kHz)Channel separation85dB (at 1 kHz, fs=48kHz)Wow & flutterLess than measurable limit
Tuner Section
No. of presets (AM + FM)6 + 18FMFrequency range87.5 - 107.9MHzUsable sensitivity11.3dBf (1.0µV/75Ω)50dB quieting sensitivity16.3dBf (1.8µV/75Ω)Strereo separation35dBAMFrequency range530 - 1,710kHzSensitivity20µVSelectivility35dB
Amplifier Section
Maximum power output50W x 4Continuous power output (RMS)
*Total harmonic distortion20W RMSX4CH at 4Ω
and no more than 1.0% THD + N
Frequency response40 - 20,000HzLoad impedance4Ω (4-8Ω allowable)Pre-output level/impedance5.0V/1kΩVideo output1.0Vp-p/75ΩSecond audio output2.5V/1kΩVideo input1.0Vp-p/75ΩAudio input1.5V/20kΩ
Monitor Section
Screen Size7" Wide Number of pixels480 x 3 x 234 Color systemNTSC
Dimensions (W x H x D)
Installation size182 x 111 x 160 mm
(7-3/16" x 4-3/8" x 6-5/16") Panel size188 x 17 x 10 mm
(7-7/16" x 4-5/8" x 7/16") Weight2.6 kg (6.7 lbs)
3. Description/Condition:
i got it used from a friend it was i very good condition. i have book and box, and remote.
4. What you are looking for: :sundown amp saz 3000 new heat sink but if i can link new and old it dont matter let me know. please send me a p.m.
5. Pictures of your item for trade:
http://s720.photobucket.com/albums/ww203/scfaust1/?action=view&current=P1060847-1.flv video
2. Specs -
MOS-FET Power Amp
USB Port (Rear)
GIGA MP3 MULTI
7-Band iEQ
J-BUS Terminal
Dual Zone Function
Head Phone Surround
Shock Proof Memory
Wall Paper Setting
Amp Defeat Switch
Tel. Muting
Tuner Section
Amplifier Section
Monitor Section
