WTT:FUSION NV 25001 for SMALLER AMP
FASTIMES
Still in Dis B!tch.....
I want to trade for something a lil smaller not much. BNIB, I've heard these can be ran @ .5ohm daily, no prob. It's the most powerful amp Fusion has. Im gonna let it go because it might be a lil too much for my one 10..lol
Its been benched at about 2000@ 12.5v but hears factory,
  • Brand New Fusion NV-AM25001 Monoblock NV Series Amplifier
  • Bi-Metallic Thermal Venting System : Features two levels of heat dispersion through a combination of alloys with complimentary thermal transfer properties
  • One-Piece Cast Structure : This reinforced bi-metallic cast structure provides extreme strength, rigidity and protection in the extreme SPL ranges
  • Recessed Anchor Points : Robust industrial standard mounting feet with discretely recessed anchor points to provide clean, secure and resilient installation
  • Multiple Fuse Protection : Multiple fuses protect internal components and are easily accessible for quick changes in a competitive environment
  • 825 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
  • 1310 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
  • 1790 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
  • Max Power Rating: 2500
  • Max Current: 218A
  • Full Rated Power Distortion (Max) 1kHz: 0.43%
  • THD @ Rated Power 1kHz/100Hz: 0.3%
  • Frequency Response Hz (-3dB): 10Hz - 250Hz
  • Signal to Noise: >90
  • Variable Low Pass Filter: 24 dB/Octave
  • Bass Boost @ 45Hz: 12dB
  • Input Sensitivity: 0.2 - 8V
  • Input Impedance: 47K
  • Fuse Rating: 200A External
FASTIMES
FASTIMES
(909)...SoCal
FASTIMES
