WTT/FS 7" and 4" for some 6.5 components
on1wheel01
Bang A Lang
1. Product: Dayton DA175-8 7" woofers (pair)
Dayton RS100S-8 4" full range speakers (pair)
2. Specs:
7" daytons
7" aluminum cone woofer with rubber surround, flat spider, and special composite dustcap. The cosmetic stamped steel frame provides a very high-class and professional look to your next speaker design. The aluminum cone offers a flat frequency response in the passband region with very low distortion. Specifications: *Power handling: 50 watts RMS/75 watts max *VCdia: 1-3/8" *Le: 1.14 mH *Impedance: 8 ohms *Re: 5.9 ohms *Frequency range: 35-10,000 Hz *Fs: 39 Hz *SPL: 85 dB 1W/1m *Vas: .58 cu. ft. *Qms: 3.31 *Qes: .70 *Qts: 0.58 *Xmax 4.25 mm *Dimensions: Overall Diameter: 6-15/16", Cutout Diameter: 5-5/8", Mounting Depth: 3".
4" daytons
The Dayton Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing a low-distortion motor system with two short-circuit paths and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price. Their low-distortion characteristics and high excursion capabilities provide exceptional clarity, detail, and dynamics. Woofers feature a shielded motor system, black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, and solid aluminum phase plug. Specifications: * Power handling: 30 watts RMS/45 watts max * VCdia: 1" * Le: .41 mH * Impedance: 8 ohms * Re: 6.3 ohms * Frequency range: 85-20,000 Hz * Fs: 85 Hz * SPL: 83.3 dB 1W/1m * Vas: .06 cu. ft. * Qms: 3.48 * Qes: 1.16 * Qts: .87 * Xmax: 3.5mm * Dimensions: Overall diameter: 3-7/8", Cutout diameter: 3", Mounting depth: 2-7/16".
3. Description/Condition: All in great shape I just need to do all 4 ohm stuff.
4. What you are looking for: :Wanting a 6.5" component set does not have to include tweets as I have some 4 ohm vefa 1" tweets already and I can add cash also
5. Pictures of your item for trade:
on1wheel01
Bang A Lang
on1wheel01
Mooresville nc
on1wheel01
