WTT:Exile x2400.1 for larger or might sell...
Lckmyblls
4 Combat Tours & Counting
*SOLD
Just as title states
Manufacturers specs: 800x1 @ 4ohms / 1600x1 @ 2 ohms / 2400x1 @ 1 ohm/ 3000 rms @.5 ohms 4800x1 @ 2 ohms Strapped /
Recomended Fuse: 200 amp
Bench Test results: X2400.1 benches out about 2450 watts... With sqaure wave, burpabble SPL power around 3000 watts......... Bench power is 1 ohm, 1%THD and 14.4 VDC...
Power/ground: 1/0 gauge
Dimensions:16.66"x11.125"x2.625"
Freq response: +- 1 db from 20hz to 300hz
Signal to noise ratio: >90db Subsonic and Low Pass Crossover: Linkwitz-Riley 24db per octave
Low pass crossover range: 30hz to 300hz
Subsonic crossover range: 5hz to 55hz
Input Sensitivity: 200 millivolts to 8 volts
Lowest Recommended load: 1ohm
Damping Factor: Greater than 200
Typical Efficiency: 85%
Force Technology
Exile's commitment to making our products bullet proof reliable. Every amplifier design fetures direct insert connectors on the power and speaker terminals for maximum current transfer and easy installation.Dual power supplies to deliver maximum power into needed loads. The circuit boards are also overbuilt with numerous buss bars, excessive capacitors, and two layer/ two ounce copper in the higher power units. These are just a few small details that illustrate how over building the amplifier, will gauruntee years of rock solid performance.
Easy Click Technology
Exiles commitment to making our products easy to use and ultra accurate for the professional or DIY installer. All crossover frequency potentiometers have 41 detents or "clicks" so the end user can set the exact crossover frequency desired. For example, turn the potentiometer 10 clicks for exactly 100Hz. No more turning the potentiometer and guessing where your crossover points are. You get exact control of your ampplifier's output.
i would sell also for $400.00 plus shipping (they go for $650.00 brand new from exile)
looking for larger amp can make its power at 2 ohm or .5 ohms i will add some cash if need be up to $150.00 let me know......
need more power for finals hate to sell but my reconed sx's with triple stiff spiders need more power........
here is my review on this amp with specs ect......http://www.caraudio.com/forum/showthread.php?t=173921
Amp guts page:http://ampguts.realmofexcursion.com/Exile_X2400.1/
Lckmyblls
Lckmyblls
Fort Campbell Ky.
Lckmyblls
