WTT: Eclipse CD7000, IPC106 (iPod), and GPS105 (AreaShot)
whitedragon551
Moderator
I have an eclipse CD7000 here. Comes with the trim ring, cage, HU brackets for mounting the trim ring, remote, harness, and the rare MEI100 tuning mic. HU has some scratches on the face and a little fading on some of the buttons, but its not to bad.
Also have the GPS105 Area shot GPS module with all wiring and original box. This will allow you to load maps via CD or Magicgate Memory stick and use them for GPS directions turn by turn and with voice prompts. It will also allow you to display on the screen direction, coordinates, or speed of your car.
Last but not least is the IPC106 ipod control module. Allows full speed play back through the HU. Once connected everything can be controlled from the face plate. You can sort by artist, song, playlist, etc. all directly from the faceplate. Also have all the wiring and original box with this.
Looking for something with active capabilities and time alignment. Just looking for something new. I will also look at double dins with those features. Must have atleast 5v preouts and iPod as its my main source of music. Something like a Pioneer P800PRS or the P880PRS, older Eclipse with the balanced line driver output, etc. Ill also consider HU's that dont have active capabilities if you have an external active capable crossover to toss in with the HU. I will not sell any of it outright. It all stays as a package for trade or I keep it. That goes for the MEI100 mic as well.
Heres some pics with an old date. MEI100 isnt pictured. Last pic of how it sits currently in my dash board. Note. The IPC106 and GPS105 are no longer new. They are used in MINT condition with all accessories.
Links for the products:
http://www.crutchfield.com/S-7zW4M6xm5aD/p_099CD7000/Eclipse-CD7000.html
http://www.crutchfield.com/S-TkN2xuvMpRd/p_099IPC106/Eclipse-IPC-106.html
http://www.crutchfield.com/S-igHJ3GpN9r2/p_099GPS105/Eclipse-GPS-105.html?tab=detailed_info
this thing can't go active? and whats the preouts on this? i thought it was 8v too?
Active capable, 2 way + sub, 5v preouts. Eclipse had an amendment to their original release that stated it had 8v, but it was wrongfully written down as such. Its actually 5v.
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
