WTT: Earthquake PH10000W/D1 AMP
look at the specs the 10,000 is a strapped pair at maxx watts,5000 is a single 1 maxx watts
have to say your right benched one out at 15.4 volts @.7 and it did 3760 that was its sweet spot would shut off if any more volts were giving to it and it didnt like to go lower on the ohm load it would run lower but super dirty and it started to loss
i've owned 4 of the phd 10,000's they are decent amps but only around 3000 at 1 ohm....and i know what i'm talking about and i also know Carlos at Earthquake Sounds.....if your looking for a 3000 watt amp you already have one...if its too much power for you and you don't understand make believe specs...you may need a 1500 true watt amp.....//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
excatly dave;)
theyre max rated at 10,000 hence the name... you've heard lol ok stay out of my thread if you're just going to bash the amp with info you've "heard"
Based on the above comments, looks like he was right. I wish it actually did rated power though, I would have been interested.
Amalan
Amalan
Cincinnati
xhilr8n
