WTT: Dynamat Extreme Bulk kit for 4ch amp
BigSix
Whippin the Bass
2 sheets missing out of kit...... looking for a decent 4ch amp....willing to add $$ if its a good deal......
you still have those xxx mids??? i have a old school jbl gtq 400/brick that i wouldnt mind swapping for those.. very presentable stste, and tested couple months ago..have copy to print out specs for it also, can be ran 4/3/2/and 6ch pm me if interested.or offer up? thanks
man i knocked off the terminals on one of the speaker trying to fix that stripped screw so I closed the thread......
i have a gemeni vii,that needs speaker plugs, but works great, and still looks decent, and got back from spoony to check it over..works great..was looking for like $120 for that rare one,i have quite a few 2ch too? what you wanting to put on the amp/rms
its still functional....the whole terminal block is just hanging......
soldering works great for that:D..you need go cheap, i have couple older amps/concord 50.2/20.2 clarion 50x2,hottsetup 300xbones, alpine duo-b 3525/3523 both rare sq amps, couple others ill have to check out see what i got..have an older sstream i got from crx, and decided not to use..pluto viii/vulcan viii
lot of speakers lol......I have two pairs of PA speakers Im gonna use on the first two channels and a component set for the other two......so basically looking for something at 75watts at 4 ohm X 4
[quote name='BigSix']lot of speakers lol......I have two pairs of PA speakers Im gonna use on the first two channels and a component set for the other two......so basically looking for something at 75watts at 4 ohm X 4[/QUOTE]
that jbl is 100x4 x4ohms @11.6v-16v no current limit and has fan built in..google it up, or send me an email @audiobaun@yahoo.com, and i can send several pics,my pic thing is full on here,wont let me put new pic/delete? amp takes 2-12-10ga power wires,that gemini is old school zed 50x4 hifonics vii under rated,shells more like 75-80
interested in the gemini...however are you sure your interested in the speakers? they need work man.....the screw is still stripped and the block is hanging
rt now in my truck i have 1-infinity 100rms old school tweet,and a 60 rms polk 6.5 on a 2wat xover, and an old school polk mm 100rms 5.25 woofer, with an infinity ref 50rms tweet on another xover tied in together running @2ohms @125 rms on each door on a 2ch hifonics vii odin, sounds great man
i should be able to fix it up, as long as the wiring is still in tact to the cone??? send me an email, and i will send you some pics of the gemeni, and jbl,and couple other amps..i prob got like 20 amps laying in my room.that orion hott setup xbones 300 is 150x2@4ohms..ill hqave to retest it, but its clean too
BigSix
Whippin the Bass
BigSix
Austin,Tx
BigSix
