WTT: DD m1a / s4a for PDX 1.1000/4.150
Flipx99
Violator of Terms
Looking to downsize my system in both wattage space, so I am looking to trade my amps for yours. I am also willing to sell these amps outright for a price of $700 shipped.
As for refs, I recently sold the sister to user "revots"...I have had several transactions downsizing equipment. I can find more refs if you would like although I am sure some previous buyers/sellers will chime in.
I purchased the amps from Louisiana_CRX around July/August.
Amps were installed and have been in continuous use since December. Before that, I kept uninstall/installing them in different configurations because I am an idiot or something.
I will try to get more/better/close up pics by Saturday. I don't have time when there is good lighting. I do not plan on uninstalling the equipment until I sell/trade my existing equipment.
Specs:
M1a
300x1@4
600x1@2
1200x1 @ 1 (user revots says he thinks it is more, I will not make those claims as I haven't tested against another 1000w amp)
effeciency: 75%
S4a
--Note: This amp has crossovers adjustable enough for active setups. I DO NOT reccomend this vs. a HU with active setup. I a/b'd them and there is a difference...Having said that, if you do not have an active capable HU and wanted to venture into it, this may be a great option, as it does sound good, just not as good.
Series
S
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
20 Hz - 500 Hz (200 - 5 kHz) at 24dB/Oct
Subsonic Filter
Variable Low Pass Filter
50 Hz - 500 Hz (500 - 5 kHz) at 24dB/Oct
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
S4
Power at 4 ohm
100W x 2ch + 200W x 2ch
Power at 2 ohm
150W x 2ch + 300W x 2ch
Damping Factor
>550 @ 2 ohm
Power at 1 ohm
175W x 2ch + 350W x 2ch
Power at 4 ohm Mono
300W x 1ch + 600W x 1ch
Power at 3 ohm Mono
350W x 1ch + 700W x 1ch
Max Dynamic Power
400W x 1ch + 800W x 1ch
Efficiency thru Output
64%
Dimensions - mm
390 L x 235 W x 53.4 H
Dimensions - inches
15.35 L x 9.25 W x 2.1 H
Signal to Noise
95 dB
Shipping Weight
16 lbs
Here are the pics installed:
Flipx99
Violator of Terms
Flipx99
Building 100
hardhitta47
