1. Product:
DC Audio Lvl 4 15" dual 2 ohm subwoofer
2. Specs:
Level 4
This sub was designed to make people angry.
With sick amounts of output, it’s hard to beat!
The Level 4 sub is a large double stacked motor weighing in at almost 30LBS each, wrapped in a magnet boot with a chrome top plate and T yoke yielding 23.5mm of X-Max
You also get with the upgraded progressive spiders, cone, surround, 3" coil, cast basket, push terminals and upgraded lead wire.
The Level 4 is rated at 1000w RMS and 2000w peak. Designed for ported enclosures and is a great choice for high-powered daily systems and competitors.
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• 8”OD semi cup progressive roll spider
• Extra heavy duty interweaved tinsel lead wire
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly – Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 2 ohm 3” Hi-temp Aluminum voice coil wound on black anodized voice coil former
• Rubber magnet cover
3. Description/Condition:
This sub is in very very good condition.
9.5/10 cosmetically only because it was used a couple times
10/10 mechanically
4. What you are looking for: :
Anything worth over $300
5. Pictures of your item for trade:
2. Specs:
Level 4
Key Features
10/10 mechanically
