WTT: Crystal MobileSound CMPX2 15
profoundwill
I have a dual 4 ohm crystal cmpx2 15 that has tore where the con and spider meets, pretty much around the glue joint. Should be an easy fix for someone or a total rebuild if you want to go that route. Both coils read fine though. I am looking for an alpine pxa-h100. Here is a picture of the joint.
I think it's a 3" coil, but I am not 100% sure. Only one needs a recone the other is perfectly fine. And the one that is messed up really only needs the cone re-glued to the spider both coils read fine but a full recone could be done if you chose to. I talked to TeamPsi about a recone, he said around $150.
profoundwill
profoundwill
Birmingham, AL
profoundwill
