for trade ive got a Critical Mass UL12
RMS Power handling: 2500 Watts (undistorted power)
Weight: 16.6 lbs
Motor Type: Dual Gap / Internal NEO Magnet
Voice Coil Type: Ultra-High Temp Dual Coil (Made in the USA)
Voice Coil Diameter: 3”
Voice Coil Impedance: 1.5 ohm nominal per coil
Xmax (one-way linear excursion): 36 mm (3” peak-to-peak)
Maximum Excursion (one way): 46 mm (Almost 4” peak-to-peak)
Sensitivity: 96.7 db (2.83V / 1m) (coils in parallel)
what im looking for
anything i can actually use. let me know what you have got. as long as its good equip or whatever.
if i traded for subs they would have to be shallow or have limited mounting depth.
SPEC SHEET for enclosures
SQ left
SPL right
coils both read 1.6ohm
the damage to the box that i have for this one since i used the other box to ship a different one.
i will be adding plenty of extra packaging to insure the sub gets there in 1 piece. i will also get some make sure the seam of the box is glued back together well.
Weight: 16.6 lbs
what im looking for
SQ left
SPL right
