WTT: BNIB, RE SE-x 10"s for a 15"
k_schutte
Like the title says... I am giving this one more quick shot before I install them this weekend. They are still brand new in the boxes. I did open them to take pictures for someone but that is it! They are 10"s, D4 coils, should be all you need to know really.
Looking to trade for a D2 15" that can take 2kw RMS daily...
Product Dimensions:
Mounting Depth - 6.4 inch
Mounting Hole Diameter - 9.3 inch
Overall Diameter - 11 inch
Bolt Hole Circle - 10.1 inch
Motor Width - 7.3 inch
Motor Depth - 3.4 inch
Basket Depth - 2.94 inch
Displacement - 0.14 cu. ft.
Weight - 21 lbs.
T/S Parameters:
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 4.4
Total Speaker Q Value -Qts: 0.42
Free Air Resonance -Fs: 26.6 Hz
Equivalent Compliance -Vas: 31 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 83.2 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 2 or 4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
k_schutte
k_schutte
cedar rapids, IA
k_schutte
