Sold WTS/WTT: Two Avalanche 15" subs and Two Diamond D5 600.2 amps
prisonernumber6
I have two AA avalanche 15s that I bought four of five years ago. Both are in excellent condition, and one of them has never seen power. $225/each shipped or I would do the pair for $425 shipped. I still have the original shipping crates, so you can be sure they will arrive safely.
I also have two Diamond D5 600.2 amps. They are also in good condition and one has never seen power (bought to run the ava, lol). I would let them go for $200/each shipped or the pair for $350 shipped.
I would also be interested in any trades you might offer on a HU, a set of comps, or a 4 channel amp. I really don't have anything specific in mind. My last HU was an Eclipse 8443. Something with a good built in processor and 4v outputs would be nice. I'm not too picky on the comps as long as they are a worthy trade. As far as the amp goes, again I'm not too picky, but something that would provide 4 channels of 70 -100watts continuous at 4ohm would be ideal.
PM me if interested. Located in Nebraska.
I've never sold anything here, but good feedback on ebay.
Avalanche 15"
● XBL2 TM enabled motor for ultra low distortion
● Single 1 inch thick magnet nearly 9 inches in diameter
● Machined top plate and black plate/pole piece (t-yoke)
● Cast 12-spoke aluminum frame with vents for voice coil
● Beefy 3 inch diameter, 4-layer copper voice coil
● Flat profile ultra rigid epoxy treated paper-pulp cone
● Custom-tooled inverted carbon fiber dust cap
● 27 mm of linear one-way xmax
● 8" diameter progressive spider
● Improved suspension design for high efficiency
● Designed and built in the U.S.A.
Fs 15.7 Hz
Qms 3.5
Qes .334
Qts .305
Vas 300.6 L
Re 3.2 ohms
Znom* 4 ohms (dual 2 ohm voice coils)
Xmax 27 mm
Sd 749 cm2
Mms 269 g
Vd 4.04 L
Pnom 800 watts
Le 2.4 mH
Cutout 14.125"
Diameter 15.5"
Depth 7.875"
Weight 37 pounds
Enclosure alignment Q .577 Q .707 Q .8
Enclosure size 4.0 ft3 2.2 ft3 1.5 ft3
Power handling 500 watts 800+ watts 800+ watts
Diamond D5 600.2 amps:
150W x 2 @ 4 Ohm Stereo
300W x 2 @ 2 Ohm Stereo
600W Bridged @ 4 Ohms (minimum impedance)
9886... It can be upgraded to 3 way active, 7 band graphic eq, 5 band parametric eq, and time correction also with the addition of the PXA-H100($115ish)
Any interest in the amp or comps?
prisonernumber6
prisonernumber6
Arizona
prisonernumber6
