For Sale is a Moroso Power Charger, it is a battery charger. It is used but in very good condition. I have used it about a dozen times in the past 6 months, and I no longer need it. It worked flawlessly for me; I added the 2 alligator clips on the ends to grab battery terminals. This unit never got too hot to touch, and worked just as the manual said it should. I do not have the original box or paper work, but I do have a printed copy of the owner’s manual that I will send with the charger. The charger cables are about 5 and a half feet long including the clips. The clips are crimped on the wire, not soldered; I never got around to soldering them, but I don’t think it would need to be soldered, the crimps are very tight.
Click Here to go to Moroso's website for more information. I am looking to sell this and buy another charger that is more suited to my application. Shipping will probably be expensive as it weighs in at around 30 pounds. I want to get $ 250 for it plus shipping.
Here is the information from Moroso’s website about their charger: Being racers ourselves, we know that there are many between round maintenance routines that must be done to keep competitive. An important part of your car that is often overlooked is the battery. You need to know that your battery is always up to full charge to keep today’s sensitive high-tech electronic devices working properly. If your electronics do not have the recommended power, your car will not run correctly, causing you to spend precious time at the track trying to troubleshoot a problem that could be easily controlled.
To solve this problem, we have extensively tested and now offer, the Moroso Power Charger. This is the last Battery Charger you will ever need to buy. It will handle all the duties you can throw at it, during either a crazy race weekend or at home in your garage or shop. The Power Charger not only charges your ordinary everyday 12-volt battery but also will charge 16-volt batteries, which are increasingly popular for racing. If that isn¹t enough, with the flip of a switch, you can charge any type of battery, including Gel Cell, Sealed, Lead Acid, Wet/Deep Cycle and “Reactor” batteries. This same charger is also a battery maintainer because it can be left to charge and then keep your battery at top working condition while your car or RV is in storage. If speed is what you¹re after, you can be sure your battery is ready for the next round of competition before you are, with near full battery recovery in about 14 minutes, based on an average voltage drop during normal racing conditions. The Power Charger¹s solid state LED indicators clearly show the current flow into the battery so you know if it¹s charging, at 80% or READY.
The Moroso Power Charger has a list of features that will make all other chargers obsolete. With this one charger, you have at your disposal a charger that you can use on your race car, your towing vehicle or the battery you had to buy in an emergency at the racetrack. You will never have to worry about not having the right charger for the job. Its compact size can be mounted or left alone for portability.
The Moroso Catalog also offers many battery connection options for different needs.
Here's some pics:
Here's some pics:
